I use TMPGEnc to make a DVD.
Input files are X.VOB and Y.MPG.
The program refuses to accept both because the audio format is not same. X is AC3, Y is mpeg1 layer 2.
Any help is appreciated.
Izzy
Izzy Katz
If you give an authoring program two files that are truly DVD compliant, they will be accepted. This includes even if one only has Dolby Digital audio and the other only has MPEG audio. If TMPGenc complains, there are other reasons.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
You can't add both clips to same track/vts but just make a new track for each clip in tmpgenc dvd author(?) and it should work fine.
Ok, I have used your advices ( every one) and finally got it done.
I always used one track and chapter, this time I did few tracks. what is the difference (exceot for mixing formats)?
IzzyIzzy Katz
DTS OR AC3 to mpeg1/2 4 divx or h264
By DRINGO in forum AudioReplies: 1Last Post: 31st Dec 2011, 11:16 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 20:28 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00
