  1. Hello everybody
    One of my pc fans makes sometimes very annoying noise, any idea what might be the issue?
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Dirty -- clean it with a brush or air.
    And if that doesn't help, they're cheap to replace with a better quality, quieter, one.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Which fan ?
    Dust in the bearings can cause nasty noises and is usually a precursor to the fan dying.
    Read my blog here.
  4. I have antec p180, and the case has 4-5 fans, I don't know exactly which one it is...
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Power each one off individually by pulling the power lead out until you find out which is the culprit.
    Read my blog here.
  6. Originally Posted by guns1inger
    I've tried but when I move the case it stops
    It's like hide and seek :P
    Sep 2003
    Northern California
    Leave the case open.
    When the noise occurs...use a use a piece of hose or
    flexible tubing held to your ear to locate the noisy fan.
    Losing one's sense of humor....
    is nothing to laugh at.
