I have a WMV file that I would like to load in Avisynth.
DirectShowScource() usually works with WMVs, but with this it says "invalid media type".
I can play it in VLC.
According to MediaInfo its specs are:
So what do I need to use this in Avisynth? Presumably a WMV2 codec? What's a good source for that?Code:File size : 30.1 MiB Format : Windows Media Overal BitRate : 372 Kbps PlayTime : 11mn 19s VBR Peak : 730681 Buffer Average : 47982 Video #0 Codec : WMV2 Info : Windows Media Video 8 Bit rate : 299 Kbps Width : 320 Height : 240 Aspect ratio : 4/3 Audio #0 Codec : WMA2 Info : Windows Media Audio 2 Bit rate : 64 Kbps Channel(s) : 2 channels Sampling rate : 44 KHz
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 7Last Post: 7th Aug 2016, 13:31 -
load miniDV in AVISynth
By magillagorilla in forum RestorationReplies: 10Last Post: 19th Oct 2011, 15:05 -
Avisynth script fails to load
By Rick-E in forum Software PlayingReplies: 1Last Post: 31st Mar 2011, 18:35 -
VirtualDub cannot properly load H.264 Lossless video from AVI or Avisynth
By Jedi787Plus in forum Video ConversionReplies: 1Last Post: 14th Oct 2009, 22:38 -
Is 2 pass encoding (wmv2) with FFMpeg possible?
By xorfodan in forum LinuxReplies: 0Last Post: 25th Aug 2007, 09:25
