Hello
OK here is the situation ... long back story but I'll not get into it: I have a HDD that has two partitions. The first partition has some data on it that will soon be moved to another hard drive meaning that eventually this partition will be empty. The second partition has Windows XP Pro installed and is the boot partition.
Can I use GParted to delete the first partition and move/grow the second partition to be the ONLY partition?
Any pitfalls I need to know about before trying to do this?
- John "FulciLives" Coleman
Backup!
Gparted also needs ntfsprogs http://www.linux-ntfs.org/ according to the http://gparted.sourceforge.net/features.php site
Another app which will do the same
http://www.partition-tool.com/easeus-partition-manager/help/resizing-and-moving-partition.htm
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 06:17 -
Question about partitioning Windows during new xp install
By jimdagys in forum ComputerReplies: 6Last Post: 5th Nov 2008, 18:57 -
Best/Ideal HD partitioning for a new WinXP Pro installation
By retroborg in forum ComputerReplies: 4Last Post: 12th Oct 2008, 08:45 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 12:38 -
Need Advice Partitioning New Comp
By videocheez in forum ComputerReplies: 5Last Post: 27th Jun 2008, 03:37
