  1. Member wulf109's Avatar
    Jul 2002
    I installed this new version and it won't open,it keeps saying install Haali Meda splitter. I install the splitter and it keeps asking the same question. I have version 1.12 and it opens without problem. I'm assuming that Haali Media splitter and Matroska splitter are the same thing,am I wright? I see in the most recent comment post that the same problem is reported.
  2. There is a bug on some system setups with that version.
    You can use 1.12 or disable the software check in the .ini config file for 1.13
  3. Member wulf109's Avatar
    Jul 2002
    Thankyou,disabling software check worked,it now loads the program. Now we'll see if it works.
