no problems are reported with Quartz - would reregistering do anything?Originally Posted by Safesurfer
Results 31 to 34 of 34
It fixed a problem I had with importing WAV files into my video editor a few years ago. DXDiag didn't show any problems (does it ever?Originally Posted by 20000RPM
) and I could play the files OK. Can't hurt.
Actually thinking about it I've run a rereg bat file before that I found on Papa John's WMM web site a while ago which was advocated for fixing some WMM problems. Here's the text for the file, you can create a .bat file in Notepad for running it.
regsvr32 /s qdv.dll
regsvr32 /s quartz.dll
regsvr32 /s wmvcore.dll
regsvr32 /s wmvadve.DLL
regsvr32 /s shimgvw.dll
regsvr32 /s msxml.dll
regsvr32 /s msxml2.dll
regsvr32 /s msxml3.dll
regsvr32 /s "%ProgramFiles%\Movie Maker\wmm2fxa.dll"
regsvr32 /s "%ProgramFiles%\Movie Maker\wmm2fxb.dll"
regsvr32 /s "%ProgramFiles%\Movie Maker\wmm2ae.dll"
regsvr32 /s "%ProgramFiles%\Movie Maker\wmm2filt.dll"
regsvr32 /s "%ProgramFiles%\Movie Maker\wmmfilt.dll"
regsvr32 /s "%ProgramFiles%\Movie Maker\wmm2ext.dll""Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
I re-registered Quartz, but no further along.
I also got the dump filter and routed the output of the camera directly to dump, but the same problem, only a few seconds.
So that's gotta be the simplest possible graph, direct from source to dump file, no splitters or decoders or anything, and it still didn't work. -
Yes, that's essentially the same graph I described (our DV writer is basically a dump filter).
I came across a tool a while ago that would let you see the messages that go up and down the filter graph. I'll try to find it.
Cannot Capture. Possible camera h/w connection problem
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Mar 2012, 18:12 -
Capture from Sony DRV530, stops after 3-10 seconds
By tepeco in forum Capturing and VCRReplies: 0Last Post: 12th Feb 2010, 16:42 -
Internet connection randomly drops out
By Eyecan'tcode in forum ComputerReplies: 18Last Post: 17th Jul 2009, 22:55 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum Capturing and VCRReplies: 4Last Post: 16th Apr 2009, 12:24 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 22:55
