Hello. I'm a long time site visitor who's just registered.
I'm trying to transfer some DV on to my Win XP SP2 machine. It's connected to my PCI firewire card, and windows detects it properly when I plug it in, bringing up the dialog box asking me if I want to capture video.
I'm able to transfer a few seconds of video, then the capture simply stops. After this point, WMM says there is no tape in my camera, and whatever I do I can't re-establish a connection with it unless I restart the machine.
The most I've managed to transfer is 1 min 20 seconds. I've tried DVIO as well, but this causes a similar problem. There's plenty of space on my hard drive, and it's formatted as NTFS.
I've patched my machine with KB885222.
Any ideas?
Thanks.
Results 1 to 30 of 34
A:
http://www.microsoft.com/downloads/details.aspx?FamilyId=A2091337-A0EA-4B34-B19F-B6EC0...displaylang=en
B:
1: Pc off
2: Dv set to playback, then connect to pc
3: Turn on pc
4: Try capturing
5: To disconnect safely, shut down pc, then remove dv from system
C:
Would also remove all non-essential devices connected by usb from system during the capturing ... helps with diagnosis ... Have you tried other tapes, another firewire cable? -
Also try it in camera mode - i.e., a live stream instead of the tape - just to help troubleshooting.
John Miller -
a: I tried a couple of times, but it seems as though this has completely stopped my PC from capturing anything at all. I am now rolling back to a restore point.
b: the PC doesn't seem to be able to connect properly unless I connect/turn on the camera after Windows is booted.
c: haven't tried this yet, but I have noticed that the IRQ numbers for my graphics card and firewire card are the same. Windows does not report any conflicts. I may try and change this... will have to look up how. -
Originally Posted by JohnnyMalaria
Re c:, "interrupt sharing" is common. Trying to set one manually would be a nightmare.
John Miller -
You might try this.
Archived from groups: microsoft.public.windowsxp.video (More info?)
Another remote possibility might be your DirectShow DLLs getting mapped
incorrectly. To eliminate this possibility re-register the qdv.dll which is
used for dv avi capture/encoding. Execute the following line on Start > Run
dialog
regsvr32 %windir%\system32\qdv.dll
if that doesnt work then try re-installing (on top of current installation)
Graphics card drivers
DirectX runtime (full download)
Windows Media Encoder"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Originally Posted by 20000RPM
Also, try the reverse process - send a DV file to the camcorder. You'll need a large file which you probably don't have (for the obvious reason) so create something with WMM (just a blank/colored screen will do) as a DV-AVI file. Then use WMM to send it to the camcorder.
One more - with XP, the camcorder will show up in My Computer as an imaging device. Open its folder to see the video coming in via FireWire. See if it keeps going uninterrupted or if it stops/hangs. This will help narrow down the source of the problem.
BTW, just about every capture app out there for Windows uses the same underlying drivers etc to do the grunt work so if one app has a problem then the others will, too (as you've seen with WMM and DVIO).John Miller -
removed procoder; nero 6 is installed but I don't think it's running anything in the background - I would have seen it using start right / ccleaner or whatever.
I am about to try a different cable connected to a different firewire port.
Don't have anby blank tapes right now to try the transfer the other way... -
no, using the other cable has exactly the same outcome: 4 seconds captured this time.
your computer specs look like an older machine. if you bring up task manager and watch what's running and how much cpu they are using does something go to 100%? and how much actual free space is on your hard drive? is it ntfs formatted? you might want to give it a cleaning it and defrag it.
Yes my machine is older, but nothing is hogging the cpu, and I've tried the capture with all non-essentials disabled, but it does not seem to make a different.
The NTFS issue would not crop up until the file was 2GB in size. The most I have transferred is about 1m 20s.
I don't think cpu / fragmented hard drive is an issue. If it were, I think I'd more likely get dropped frames than a connection that 'drops' and won't come back again.
-edit-
I keep my machine fairly clean with regular ccleaner runnings, defrags, etc. -
Right, this is interesting:
Following what JohnnyMalaria said, I connected in cam mode. I opened the camera in Windows explorer, and saw the preview image on there. It seemed to maintain connection for as long as I wanted. Even switching into playback mode and then back into cam mode, the connection was not dropped. As soon as I then started to capture a tape, the normal problem showed up again.
The above was done with the network cable unplugged, firewall and AV disabled, a few other services disabled and all other apps stopped.
So, the problem is purely with capturing. Whether from a tape, or directly from the camera, capturing is where the problem is.
Are we any further along, do you think? -
The next thing I'd recommended is to use GraphEdit to roll your own capture tool. It's the most fundamental way to capture - no frills etc that may be interfering. I'll provide instructions a little later. You can also try our software (see sig) and test it in viewing mode and capture mode to see if the behavior is the same as you've seen already.
Re sending back to the camcorder, you don't need a tape - you can just view the video on the camcorder's display.
Your PC's display can also upset capture. If the video mode is changing for some reason and your capture program is showing the incoming video, the capture process can end up being reset. screen savers, pressing Ctrl-Alt-Del, dragging things from one display to another etc are known causes.John Miller -
Looking in Gspot, the following are showing:
Code:VFW DVSD Cedocida DV codec (SD format) v0.1.6 vidc.dvsd 0x00200000 quartz.dll --> cedocida.dll DSH DVSD DV Splitter {4EB31670-9FC6-11CF-AF6E-00AA00B67A42} 0x00600000 qdv.dll DSH DVSD WMT Virtual Renderer {930FD02C-BBE7-4EB9-91CF-FC45CC91E3E6} 0x00200000 wmm2filt.dll DSH DVSD DV Video Decoder {B1B77C00-C3E4-11CF-AF79-00AA00B67A42} 0x00800000 qdv.dll DSH DVSD Nero DV Splitter {F85D4921-9741-46AD-9CDE-206A7F47DBA1} 0x00200000 NeDVSplitter.ax
The Cedocida codec is a Video for Windows codec used for decoding. It, like all VfW codecs, isn't used during capture nor by any DirectShow-based applications.
The Nero splitter shouldn't be a problem because it has a lower 'merit' than the MS one in qdv.dll. Only programs that explicitly ask Windows for the Nero splitter will end up with it.
I suggest trying the following with GraphEdit (click on the link to the left to find out how to get it. Use the 'older versions' link unless you want to download the entire MS SDK):
Open GraphEdit
Choose Graph\Insert Filters...
Find "Video Capture Sources" category in the list and expand it.
Choose the "Microsoft DV Camera and VCR" entry
Click Insert Filter
Click Cancel
On the filter box that has appears, right click on the little square named "DV A/V Out" and choose "Render Pin"
A bunch more boxes will appear such that the 'graph' looks something like:
Microsoft DV Camera and VCR--->DV Splitter--->DV Video Decoder--->Video Renderer (and the same DV Splitter--->Default DirectSoundDevice).
Click the green arrow button in the toolbar. You should see and hear the video from your camcorder. If it stops, click on the DirectSoundDevice box and press delete. Now try again. If it works properly, it indicates an audio issue. Chances are, though, everything will behave.
Now try capturing to a file. Save the above to a suitable file so you can load it later if needed. This time:
Choose File\New to start afresh.
Add the Microsoft DV Camera and VCR as before.
From Insert Filters, find the DirectShow filters and insert the "AVI Mux" filter and the "File writer" filter. You will be asked for a file name - make sure you give it an AVI suffix.
Join the filters together: MS DV Camcorder and VCR--->AVI Mux--->Filter writer. To join them, click on the filter's output pin (the little box) and, while holding the mouse button down, drag the cursor across to the input of the next filter (you'll see a line with an arrowhead).
Save this graph.
Click the green arrow button.
This will be capturing the video just like WMM, DVIO etc do so it should experience the same issue. If it does then it tells us the problem lies within the DirectShow part of the OS. If it doesn't then something else is going on. Depending on the results, a couple more graphs can be tested.John Miller -
Thank you very much, JohnnyMalaria. I'll give that a go when I can restart my machine (duty calls for now)...
JM - exactly as you stated - fine for 'live' view, but capturing stopped after only 2 seconds.
no audio problem with the live preview.
Hmmmm... -
What hard drive are you using? Is it the same physical drive that your OS is on (even if a different partition)? If so, you should use a separate drive...but your symptoms are quite odd.
Right, I have tested the Graphedit capture to external drive and it captured 5 seconds.
I also tested watching the tape without capturing, like I was watching the live picture, and that's fine. I can even pause or stop the tape and start it up again and it's fine.
So, there is some problem with actually rendering it to file.
I may try saving raw video and audio data without muxing it to avi and see if that works. What do you think of that? -
You could also try capturing to a raw DV file (instead of AVI) to see if that works. Our DV processor comes with the Enosoft Raw DV Writer filter that you can use in GraphEdit. You can just connect the output of the Microsoft DV Camera and VCR to the input of the DV writer filter. It can't get any simpler(!) If it works but AVI doesn't then that will help narrow down the search further. If it still doesn't work, the next stage might be to snoop the graph and watch for error messages that DirectShow sends to the applications using it.John Miller -
I have 10 errors, including the three below:
- Nero Digital AVC Video Enc
- {61D528DA-7582-4336-9E9B-092D7C127F5C}
- QuickTime Video Decoder Filter
Originally Posted by JohnnyMalaria -
I can't install it because my cpu does not support SSE2, apparently.
I have just run a test. I built a graph in graphedit, but this time, only took the audio from the dv splitter. I put that into the avi muxer, and then to the file writer and it seemed to capture fine.
So, writing just the audio to file seems to work. I did 2m41s just now before I stopped, and the connection was still active afterwards, which I tested by watching some live video.
I've just run another test: taking the video only pin from the source and connecting that directly to the avi muxer. No dice - only 14 seconds before the connection dropped.
Capturing uncompressed rgb video frames (as in, the output of the decoder) does not work either. -
Have you tried reregistering the quartz.dll file as well (Start>Run>regsvr32 quartz.dll)? Reboot and see if any change.
Cannot Capture. Possible camera h/w connection problem
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Mar 2012, 17:12 -
Capture from Sony DRV530, stops after 3-10 seconds
By tepeco in forum Capturing and VCRReplies: 0Last Post: 12th Feb 2010, 15:42 -
Internet connection randomly drops out
By Eyecan'tcode in forum ComputerReplies: 18Last Post: 17th Jul 2009, 21:55 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum Capturing and VCRReplies: 4Last Post: 16th Apr 2009, 11:24 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 21:55
