I know that I can, with software, convert from Microsoft WORD to ADOBE ACROBAT.
But, is there a way to convert from Microsoft WORD to ADOBE ACROBAT? And is there a way to take an image off of ADOBE ACROBAT?
Thanks a million
bryan kendall
http://www.cutepdf.com/Products/CutePDF/writer.aspCutePDF Writer installs itself as a "printer subsystem". This enables virtually any Windows applications (must be able to print) to create professional quality PDF documents - with just a push of a button!
http://www.downloadsquad.com/2008/08/05/how-to-extract-images-from-pdf-files-without-u...copy-and-past/PDF Image Extract is a free Windows utility that does exactly what the name suggests: it extracts images from PDF files.
Good luck!!! -
Assuming that you meant ".PDF to .DOC", yes there exists pdf2doc
(and pdf2html as well) --- Google for both.
As for "any-printable-type-of-file" to .PDF, GhostView (sort of GUI for
GhostScript) is a reasonable 100%-free option.
Click on the "Graphics Select Tool" button, then select an image, then pressAnd is there a way to take an image off of ADOBE ACROBAT?
"CTRL + C".
P.S.: You meant "Acrobat READER", didn't you
Adobe Acrobat Reader Save and Open Location?
By bevills1 in forum ComputerReplies: 5Last Post: 24th May 2011, 17:55 -
Acrobat Pro X not opening files within an IE window
By Toastie in forum ComputerReplies: 1Last Post: 22nd May 2011, 13:49 -
Distributing Acrobat Reader on CD-ROM
By xavierp in forum ComputerReplies: 7Last Post: 10th May 2010, 12:53 -
Upgrading from Acrobat 07 to 09 Question
By RKelly in forum ComputerReplies: 5Last Post: 13th Aug 2009, 13:42 -
Acrobat Reader - process in RAM
By Ai Haibara in forum ComputerReplies: 5Last Post: 3rd Jan 2009, 02:48
