Hey guys,
I have been having this wierd problem with AVIDemux. The converted files go out of sync. The audio is by itself delayed by 1-2 seconds.
I used AVIDemux to append 3 VOB files, set the encoder as x265, added the filters, set the audio as "Copy", hit save, and saved the file as whatever.avi. After processing, the outcome is out of sync. Anyone know why this is happening and how to fix this?
Thanks!
If the three VOB files are from the same DVD....is it MUCH better to let your ripping program rip them as one large file. The audio sync data travels along each VOB and are linked to each other. Taking just certain VOBs from discs often causes sync problems in editing software.....not just AviDemux.
Personally.....I would rip the entire DVD to one giant VOB with something like DVDDecrypter(if possible).....then edit and output. -
DVDDecrypter rips the whole DVD's files on to my HDD. It doesn't give me one VOB file. You know how to rip it to one file?
File Splitting - NONE option under TOOLS - SETTINGS - IFO MODE.Originally Posted by th3obr0
I'll really need to try that app someday. I keep forgetting about it.Originally Posted by guns1inger
Old Dog - New tricks...."know what I mean?"
I just used a VOBJoiner to join the splitted VOB files. I will try that "No Splittin" settins next time
Will report back with it later!
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 14:35 -
avidemux audio out-of-sync problem
By scarlac in forum Video ConversionReplies: 3Last Post: 20th Sep 2010, 11:37 -
after using avidemux, audio is out of sync
By michael12happy in forum Video ConversionReplies: 2Last Post: 26th Apr 2009, 09:48 -
AVIDemux 2.4.1 cutting audio or maybe video sync issue
By ColdFusion2 in forum LinuxReplies: 9Last Post: 11th Sep 2008, 10:27
