I'm trying to capture some stuff with WinDV and it's acting up splitting files at abnormal sizes when it shouldn't be splitting at all. I've got 18 tapes total from one day that are all new recorded at once with no pauses. I've for WinDV set for type 2, discontinuity threshold of 1, max size 1,000,000 frames, every n-th frame at 1. With these settings it should capture a single file until the timecode on the tape stops, correct? It is capturing up to 7GB and then splitting into a bunch of smaller size files that are all different.
I'm capturing onto a 1TB Western Digital My Book that is 2 weeks old and formatted in NTFS. Dropped frames are not a problem and I captured one tape fine with the discontinuity set to 0. I'm running Vista Home Premium with SP1 if that could mean anything. I use the same settings on my XP desktop and have no issues. Any ideas?
Flaws on the tape causing discontinuity errors?
Edit: Setting DT to 0 will capsfer it all as 1 file, but won't stop at the end of the timecode on the tape. You could try increasing the DT to 3 or 4. That might make it ignore small errors."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
I want it to stop at timecode end. I tried setting DT at 5 at first. The one tape I transferred successfully stopped at timecode end even with DT set to 0. My Vistap laptop seems to act differently than my XP despktop.
Might be a Vista thing then. I don't have Vista, so I can't confirm or deny...
Buy My Books -
That's what my gut feeling is. I just finished a second tape with DT set to 0 and on the Vista laptop it stops at timecode end.
KMPlayer acting weired with subtitles..
By LonerPrime in forum SubtitleReplies: 0Last Post: 7th Feb 2011, 15:35 -
VobBlanker acting strange
By pcb in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Sep 2010, 17:00 -
Mp4cam2avi is acting up!
By 24fps in forum Video ConversionReplies: 3Last Post: 21st May 2010, 22:54 -
iMovie acting up
By Nilfennasion in forum MacReplies: 4Last Post: 13th Nov 2008, 09:28 -
FCP acting strange
By James in HD in forum MacReplies: 1Last Post: 12th Oct 2008, 00:06
