Hi folks,
Q: I have a dumb Q ... does it matter ... performance wise using .zip or .exe version of AviDemux.
I have gotten used to using the .zip type ... on the "assumption" that zipped version of any program might be
1) "Safer" to use
2) Easier to unistall
Any thoughts would be appreciated! Thanks!
G!![]()
No essential difference between the zipped package and the "installable" one.
The non-essential difference: the end-user actually does not need a "stupid installer"
(according to the great Alex Noe
Hi Midzuki,
THANKS. I love the programs that are "Self-contained" and "Portabelish".
G!
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
.Exe vs .Zip Programs
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2009, 03:30 -
What is your most used zip compression utility?
By yoda313 in forum PollsReplies: 39Last Post: 30th Jun 2009, 16:00 -
Can't unzip ffmpegXbinaries20060307.zip
By cerebusthe2nd in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2007, 08:39 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42
