When burning a movie copied to hdd with ImgBurn I notice the DVD total size is about 600,000k (with the movie I tested) bigger than burning with Nero; the burnt Nero DVD actually came out the same size as the movie's VIDEO_TS file (which makes sense since the AUDIO_TS folder is empty), where the VIDEO_TS file on the ImgBurn disk is also the same size but the actual DVD is bigger as though there are some "hidden" files added. Ideas?
Also, I tested FixVTS and when playing the movie back it played thru track9, then jumped back to track3, played again thru track6 and then jumped to track11 or something like that. Although I started/aborted FixVTS a couple times in the beginning of the app running it did say it finished successfully.
Results 1 to 1 of 1
Question about possible virus that won't allow seeing hidden files
By jimdagys in forum ComputerReplies: 24Last Post: 1st Dec 2009, 08:09 -
Solved: How to change forced hidden attribute of folders/files
By jimdagys in forum ComputerReplies: 0Last Post: 1st Jul 2009, 01:07 -
Can ImgBurn burn .tib files?
By rocky12 in forum ComputerReplies: 5Last Post: 22nd Jun 2009, 06:48 -
some strange issues when using bdrebuilder and imgburn
By tomrip in forum Blu-ray RippingReplies: 2Last Post: 24th Feb 2009, 22:18 -
Verbatim DVD+R DL burn issues with Nero and ImgBurn
By prvittal in forum Authoring (DVD)Replies: 7Last Post: 21st Aug 2007, 20:42
