I need to record 4 different radio stations on my PC (Windows XP). I'll have a separate radio tuned to each station I need. I'll connect a line from each radio's headphone jack to my PC. I was thinking of using High Criteria Total Recorder to capture the audio from each line. I think I can just run 4 instances of total recorder and set each instance to record from a separate line. I don't need excellent quality audio. I basically just need the quality to be good enough to hear the commercials during the radio programs I'm recording.
How do I set this up? Will Windows XP support multiple line inputs? Is there a single sound card that I can install that has multiple line inputs, or do I have to install a separate sound card for each line input? Would I be able to install multiple identical brand sound cards? Or do I just use a mixer to do this?
Remember, the line I'm using will need to go from the radio headphone jack to the PC.
Any specific instructions on how to accomplish this are greatly appreciated.
There are lots of multitrack sound cards. For example (10 tracks):
http://www.newegg.com/Product/Product.aspx?Item=N82E16829121011
If you need to record four stereo stations you'll need eight channels. If you only need mono a four channel card will do.
I've never used more than two channels but but there are many multitrack recording programs. They may put everything in one file though.
LG Rh399 Timer Recording from AV Input
By Bashar in forum DVD & Blu-ray RecordersReplies: 5Last Post: 18th Jul 2013, 01:08 -
Here's an interesting question, recording a streaming radio station
By Nator in forum AudioReplies: 4Last Post: 29th Jan 2012, 13:30 -
[Hauppauge PVR 150] Any Ways to Live-Record Mic Input AND Line-in Audio?
By darkarn in forum Capturing and VCRReplies: 0Last Post: 27th Jul 2010, 20:13 -
Mini DV - using the 1/8 " Mic input for LINE level sources
By dizzyzuma in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 7th Jun 2010, 19:07 -
Remove commercials from a radio recording mp3
By jmiller29 in forum AudioReplies: 10Last Post: 27th Jun 2007, 12:49
