Hi there,
I'm currently using Nero Vision Express 3 to author and write avi files to DVD. For one particular project I am getting an error message immediately saying 'Burn Process Failed!' when it begins transcoding. For some reason it only happens with this project and not any other, all the settings are correct as far as I know, the avi file is large 4 hours long and 4.5GB in files size - any suggestions?
Cheers!
Its a Nero software issue, that will prohibit copy-protected files from being reproduced. Even if your source file is a copy of a copy, or an edit. Nero is very sensitive to encoded files. Even if its not truly commercial copy protection, it will still fail the burn process. If you read the text file of the failed burn, watch for this phrase: Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)...
Well you could try 2 things.Originally Posted by tatester
Run it thru Avidemux. It usually asks to do a number of things... let it do them and then File-> Save-> Save video, leaving it in 'copy'. Note use a complete file name xxxx.avi.
You could also try the same with this app.
http://www.alexander-noe.com/video/amg/
Hit generate-> Start and try that resultant AVI.
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 16:28 -
Sudden problem with Nero Vision Express 3.1.0.0
By smackyourfupa in forum Authoring (DVD)Replies: 8Last Post: 3rd Nov 2007, 17:56 -
AVI won't run in Nero Vision Express 3
By loninappleton in forum Video ConversionReplies: 3Last Post: 9th Oct 2007, 14:33 -
better tha nero vision express
By cesarin in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 14:34 -
join and burn using winavi and nero vision express?
By leogeo in forum Authoring (DVD)Replies: 9Last Post: 11th May 2007, 07:56
