I have an Acer Aspire 6920 and I've ben trying to watch some mkv files using the comunity codec pack and windows media classic (already tried k-lite codec and vlc) and I always get the same problem after a wille (it's not a well defined period) the video starts to get very slow and the audio all out of sinc and it's impossible to watch.
I dont think it is because the hardware seing that it runs quite well for some time.
If anyone could help would be great.
I have Vista Ultimate 32 bits with 4gb Ram (I know)
Tried that but didn't work...keeps geting all jumpie and out of sink after 10 minutes
Most playback issues are codec related. Since you have multiple players installed as well as a a couple codec packs, you are likely in a world of hurt trying to get it fixed. Try uninstalling all of your video players and codec packs using Add/Remove Programs. Reboot and try using an app such as CodecSniper to clean up any leftover codecs. You may also want to run a registry cleaner or two.
Then start over using Baldrick's suggestion above.Google is your Friend
Need 12 cell battery for Acer Aspire One ZG5
By V Bot in forum ComputerReplies: 4Last Post: 18th Feb 2011, 16:14 -
Acer Aspire Wlan
By didikai in forum Video ConversionReplies: 2Last Post: 19th Nov 2010, 18:44 -
Acer Aspire ???
By HotDamn! in forum ComputerReplies: 11Last Post: 19th Apr 2010, 12:07 -
WIFI Problems on ACER ASPIRE 5920G
By Damned4eternity in forum ComputerReplies: 5Last Post: 18th Aug 2009, 12:21 -
Acer Aspire 5920G WLAN Keeps Disconnecting
By Squid_uk in forum ComputerReplies: 14Last Post: 21st Aug 2008, 18:34
