First off I'm new here so hello everyone,
Anyways, I recently got a couple of blu-ray movies in .mkv format. I wanted to convert them to AVI so I could play them on my Philips DVP990 dvd player that supports AVI playback. Before I had made an account here I was searching around and found out about "MKVExtractGUI". I downloaded it and when I would start the demuxing of the video/audio it only demuxes the first 25 minutes and just stops there. I can play the mkv from stop to finish so I know it's all there, but when I look at the demuxed files the video file is only 256mb (the mkv is over 2gb so that didn't seem right) and the audio (which I opened in VLC) is only the first 25 minutes from the movie so I'm guessing that the video is the first 25 minutes as well. I tried to demux both the audio and video separately instead of at once and I got the same thing. About a week ago before I tried demuxing, I had tried to convert the movie via SUPER converter and I got the same exact thing. Since this happened with both SUPER and MKVExtractGUI is it my video file that is the issue? If so, is there any way to get around this?
Thanks![]()
Results 1 to 10 of 10
How big is the MKV and how big is the 25 minutes avi ?
If it's not running up against some kind of file size limit, (fat32?)
then perhaps the avi is corrupt. -
The MKV is 2.5 GB, the output of the demux is not an avi though, it is a .h264 file that is 255mb. I have 100 GB of free hard drive space so size shouldn't be a problem. Also, I just realized that if I were to open up the MKV and just click randomly on the progress bar to random parts of the movie it would freeze up and crash if i skipped around to much (this crash happened with VLC, Media Player Classic, and Windows Media Player). Could the fact that this crash happens when randomly seeking around the movie be the problem? I don't know if the mkv is corrupt though, because when I play the mkv without skipping around it plays fine.Originally Posted by davexnet
The .mkv might be corrupted if it crashes on seeking. What are you using to decode in mpc? haali media splitter + ffshow?
You could try xvid4psp to convert it; use the AVI Hardware profile -
I am using FFDSHOW for decoding with MPC, I'll give XviD4PSP a shot, the main thing is that I want the video/audio quality on the avi to be similar to that of the blu ray mkv. Can this be done with XviD4PSP? If the video specs are needed I can post them up when I get the change (I am not on my home computer at the moment)Originally Posted by poisondeathray
If your .mkv is HD, the answer is no.Originally Posted by avkhatri
Standalone units for XviD/DivX usually only support SD resolutions (ie below 720 x576) -
Quality loss is unavoidable when you are re-encoding using lossy formats (e.g. xvid)
You can minimize that quality loss by using a higher bitrate (lower quantizer) / bigger filesize . In the settings, set the quantizer = 2 and the quality loss will be barely noticeable when playing. If you want to keep 6channel audio, you have to convert to AC3, so don't forget to change that in the settings as well -
I go to video-->encoding settings and then quantization but how can I change it to "2" I don't see it anywhereOriginally Posted by poisondeathray
Convert MKV to MP4 (Lossless) using MKVExtractGUI + MyMP4Box GUI
By ilimitus in forum Video ConversionReplies: 6Last Post: 4th Feb 2016, 12:17 -
MKV to MP4 Hell (MKVExtractGUI and YAMB)
By Axmann8 in forum Video ConversionReplies: 2Last Post: 6th Dec 2011, 05:50 -
Tool for Editing MKV Without Re-Writing Entire File?
By Wardrop in forum Video ConversionReplies: 3Last Post: 14th Jul 2011, 06:17 -
Can't start to work neither MKVExtractGUI nor PopCorn MKV AudioConverter
By mahogany in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2009, 23:00 -
MKV, Subtitle and MKVExtractGui Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 5Last Post: 20th Apr 2008, 13:43
