Currently, my PC is not showing the menu cursor or any subtitles at all when playing a DVD, on any player I have.
How do I get them back?
You could try VLC. It should be able to display subs on it's own. Or you might install VSFilter / DirectVobSub to enable subs for your other players.
No, it worked just yesterday, both Media Player Classic and GOM Player showed the menu cursor and DVD subtitles, but now they don't work anymore. And VLC Media Player is what I NEVER go for. Any other ideas?Originally Posted by redwudz
Then something has disabled/turned off your subtitle display. I don't know if those two players use VSFilter / DirectVobSub for sub display, but I wouldn't be surprised.
Actually, one of my codecs has expired. Does anyone know which one?Originally Posted by redwudz
I think I know why they were disabled. I don't have a separate DVD player on it. The problem's solved now, thanks.Originally Posted by redwudz
Old XP Computer Boots to Black Screen and Blinking Cursor
By p_l in forum ComputerReplies: 57Last Post: 13th Apr 2012, 13:45 -
Menu for subtitles
By AlecWest in forum Authoring (DVD)Replies: 3Last Post: 23rd Dec 2009, 13:54 -
TMPGEnc Authoring Works 4, incomplete button cursor link
By dzsoul in forum Authoring (DVD)Replies: 0Last Post: 26th Mar 2009, 19:30 -
Wot the fark is this? I get this popup everytime my cursor touches a video
By jaxxboss in forum ComputerReplies: 6Last Post: 22nd Jun 2008, 10:28 -
Laptop cursor moves on its own
By dimtim in forum ComputerReplies: 8Last Post: 1st Oct 2007, 12:07
