Hello, I just recently bought myself a Canon HG10. I've been trying to figure out exactly what configuration on what program (yes, I have seen all the posts for conversion methods, I'm just not sure which is the one with the least or NO loss in quality) would allow me to get the best results. File size is not an issue for me, and I just need the best quality from the conversion. I've tried exporting as uncompressed AVIs, but they distort the pixel ratio, and for some reason the footage becomes heavily interlaced (now, I'm not entirely sure if it's becoming interlaced or whether it's just a problem with the conversion causing it to look like it is). Either way, I'm using Sony Vegas 8, and hoping to export it to the best possible format to be able to edit with Adobe After Effects.
Thanks in advance.
Maybe the Debugmode FrameServer will work to frameserve to after effects. No quality loss and no conversion.
I just did that, and it did the frameserve fine, but when I rendered out from After Effects, using the lossless setting, it came out all choppy.
Best format to convert HD videos without losing quality?
By fabitos in forum Video ConversionReplies: 19Last Post: 4th Dec 2011, 00:22 -
MKV to AVI - can you convert without losing quality?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2010, 08:52 -
Convert AVI to MPEG-1 without losing quality: What tool?
By GeekyChocolate in forum Video ConversionReplies: 8Last Post: 28th Mar 2009, 17:42 -
Want to convert from VOB to .mov without losing quality
By kleiber in forum MacReplies: 5Last Post: 14th Feb 2009, 08:00 -
??how can ı convert hdrips to dvd without losing quality??
By roboroach in forum Blu-ray RippingReplies: 12Last Post: 27th Nov 2008, 21:49
