    Jan 2003
    Nassau, Bahamas
    Hi Guys, here is my problem.
    This is my motherboard, http://www.newegg.com/Product/Product.aspx?Item=N82E16813131319
    It says i can use ddr2 1200 dual channel ram. Only problem is, I CANT FIND ANY!!!!!
    Is this some type of special ram? I can only find ddr2 8500 dual channel on tigerdirect? Should i go with that, is there a 1200 out there i can get, and where. If im gonna push the board, i would like to "MAX spec" it out. Hope to hear from you soon.
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Dec 2006
    Here,where do you think?
    Did newegg not have it?
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2000170147%201052427 322&name=DDR2%201200%20(PC2%209600)
    " Who needs Google, my wife knows everything"
  3. Banned
    Freedonia
    When I need memory, I ALWAYS go to either
    http://www.crucial.com
    http://www.kingston.com
    I don't go to NewEgg because frankly, it's just easier to get the right memory at Kingston or Crucial and NewEgg's prices on memory usually aren't better.
    Crucial says this is what you need:
    http://www.crucial.com/store/listparts.aspx?model=Maximus%20II%20Formula&pl=ASUS&cat=RAM
