How do you add a second audio track to a video that I purchased online. My question stems from I want to sell workout videos online in the format for ipods...however, I cannot add music tracks because of copyright. I would like to know if there is an easy way to give advice to my customers on how to add (there already purchased) music to my narrated videos they buy. Also, if they can do this is it easy to adjust the volume of the 2nd audio track so that it doesn't overlay to loud of the narration?
Thanks, Ryan
I think you're asking too much of your customers. You should be able to find some inexpensive royalty free music with a good beat for exercising to. Google "Royalty Free Music" for tons of options.
Buy My Books -
I have already looked in to that...but not everyone likes the same music I like. Also, those royalty free music cds are expensive about 100 bucks for 1 cd. So, if anybody can answer my original question...i would appreciate it.
You can use yamb, to add tracks to .mp4
While PC software media players can switch audio tracks easily, I am unsure if the ipod can.
You could also remove the old audio and replace it with the new audio as well, if the ipod cannot select tracks.
I don't think you can play 2 audio tracks simultaneously (which I think you are asking about). You would have to re-master the audio & mix the existing narration with the new audio. You could do this in an audio editor, then export as aac , then remux into the .mp4. 99.99% of your customers will probably find this difficult -
Video has to be re-authored. It is not easy but it has to be extracted into mpeg and re-authored then add more tracks to it. By doing so you will loose the fancy menus. I guess VOB editor could be used but it is very difficult for non video professional.
Adding 2nd audio track to specific location...
By tweeker404 in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2011, 00:53 -
Adding a second audio track to a DVD-R
By danielmak in forum MacReplies: 1Last Post: 30th May 2010, 22:31 -
Adding A Second Audio Track
By DeathStalker77 in forum Authoring (DVD)Replies: 0Last Post: 11th Aug 2009, 02:16 -
Adding an Audio/Music Clip into the main Audio Track?
By Moontrash in forum EditingReplies: 3Last Post: 20th Nov 2007, 18:45 -
Extracting 2nd audio track from avis
By guy with a stick in forum AudioReplies: 1Last Post: 18th May 2007, 22:54
