Hi, Does anybody know of a DVD player that will play VCD movies full length that are burned on 99 min media? I have Pioneer 603 and 302D and Apex 500W. They will only go about 88 min on these discs. The movies play just fine in my computer for the whole 99 min (Samsung Drive). ......... Harrymj3
I have the following dvd players and they all play 99 min cdr's with no problems, I would check your buning process.
Pioneer dv-c503
fisher s1100
apex ad660
daewoo tv/dvd combo -
I have the following DVD players and I have burned CD-R's to 98min. 45 sec and they play right to the end, I had to stay with my 2 HP burners because nothing else burns 99min. CD-R's correctly.
Apex 660, 600a, 500w
Daewoo 5700
Panasonic RV31, RV32, RA60
Pioneer 343 -
Same here....
I have a Pioneer 535K DVD player and it plays up to 88 minutes only.
I burn VCDs using Nero 5572 and LiteOn 24 10 40 CD writer.
Do I need a special setting in Nero? I just use the default settings and when I burn more than 80 minutes, it promts me that the file size is more than the CDR size (I'm using a 99min CDR). Anyway, I just press Ok and continue burning. No errors at all. -
Being the one that started this subject I must tell you that I found a player that plays my 99 min CD movies without a hitch. I was at my daughters house for supper and tried it in her GE1101P. It played just fine right to the end, 99 min 15 sec. I stopped at Walmart on my way home and bought one for myself. $119.95. ........ Harrymj3
LCD TV, when playing DVD turns green after 20 min of play...????
By boston_012 in forum Newbie / General discussionsReplies: 12Last Post: 9th Aug 2009, 21:11 -
Looking for software to select 10 min clip from DVD
By jimdagys in forum EditingReplies: 3Last Post: 17th Apr 2009, 08:20 -
Is there a Min/Max limit for I, B & P frames for NTSC DVD ?
By Movie-Maker in forum Newbie / General discussionsReplies: 13Last Post: 6th Nov 2008, 13:51 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:20 -
Any downsides to importing/editing/exporting a DVD in 15 min instead of 1h
By c627627 in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2007, 21:14
