hi
how to do it
putting 5.1 dolby or dts on cd-r
and are there program to do 5.1 audio other the soundtrax?(nero)
thanks
Results 1 to 14 of 14
if you convert the multichannel files to pcm wav with a program like dbpoweramp and copy them to cd they should play. the only sticking point may be the dts, as it may require your amp to have a dts decoder built in to play them.
"spdifer.exe", from the ac3filtertools package.Originally Posted by ayyak
Code:[C:\] =>spdifer Spdifer ======= This utility encapsulates AC3/DTS/MPEG Audio stream into SPDIF stream according to IEC 61937 This utility is a part of AC3Filter project (http://ac3filter.net) Copyright (c) 2007 by Alexander Vigovsky Usage: spdifer input_file output_file [-raw | -wav] Options: input_file - file to convert output_file - file to write result to -raw - make raw SPDIF stream output (default) -wav - make PCM WAV file with SPDIF data (for writing to CD Audio)
Some program like Adobe Audition can create surround audio. If you create 2 folder AUDIO_TS and VIDEO_TS just like dvd and put your audio into the audio folder a dvd player will play it. Some sound cards create dolby digital 5.1 or DTS on the fly from stereo sound and because of copy protection there are no software or capturing audio device in 5.1.
The link is a pro Software but for home entertainment I think the sound card option is the cheapest and easiest .
http://www.dts.com/Pro-Audio_Software/DTS_Surround_Audio_Suite/DTS_Encoder.aspx -
Shouldn't besweet be able to do this? Or is it besplit? I remember being able to do it with a version of besweet. I don't remember the process I used but I got it working. FYI the cd player I used at the time was a cd recorder with fiber optic output and my amp has both dd and dts decoding so I could hear it.....
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Just burn the ac3 file with imgburn or cdburnerxp as a data cd, my dvd player reads themOriginally Posted by ayyak
you can create 5.1 ac3 using BeLight or DaudioKOriginally Posted by ayyakI love it when a plan comes together! -
The audio needs to be encoded at 44.1kHz instead of the DVD standard 48kHz, and put in a wav wrapper. It can then be burned to a CDR as a standard CD track, but is only playable on a player this connected via digital connection or does it's own decoding. On anything else it will sound like pink noise (is, in fact, pink noise) and could blow your speakers if the volume it too high at the time.
Read my blog here.
guns1inger...i tried all means and generated audio CD with DTS tracks as mentioned above, but still i get noise through my DTS signal on the receiver lights up but only noise.
Procedure as follows
Input files : 48 KHz ac3 (5.1) files
Used BeSure + BeSweet +Surcode 1.0.20 (Surcode 1.0.9 crack doesnt work) output to PCM WAv files and burnt a Audio CD- No luck
Used Headac3he to resample the files to 44.1KHz and then convert them to WAV files and then burnt to Audio CD - noluck
Any ideas here please
Zorro
Can't put to work Popcorn MKV Audio Converter
By mahogany in forum Newbie / General discussionsReplies: 5Last Post: 23rd Nov 2013, 12:29 -
How to put new audio track to MKV file??
By golafs in forum EditingReplies: 1Last Post: 21st Nov 2011, 03:19 -
Is it possible to put main audio on a ps3 through a bluetooth headset?
By yoda313 in forum Off topicReplies: 2Last Post: 4th Jan 2010, 18:26 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
Want to put WAV. Audio on DVD. Why not?
By happydog500 in forum AudioReplies: 33Last Post: 21st Jul 2008, 20:48
