Ok here is exactly what i've done:
1) Decrypted a DVD made on a standalone recorder using IFO mode of DVD Decrypter to one large .m2v file and .ac3 file.
2) I wanted to reauthor the DVD in Encore, but the video was 704x576, which Encore usually re-encodes, which i don't want.
3) I therefore did a trick i usually do, used DVDPatcher to patch the M2V to 720x576. This adds a green bar of 16 pixels to the side.
4) I then authored in Adobe Encore CS3 as usual, and it doesn't re-encode.
5) I now have my output VIDEO_TS folder, which has 4 .VOB files, as the size is ~3.6GB. I then take the .VOB file back to DVD Patcher to patch them back to 704 pixels. This works fine with the first two VOBs. However, when i try to add VTS_01_3.VOB and VTS_01_4.VOB, DVDPatcher says "No Sequence Header Found" and tells me to select a valid MPEG2 file.
Now i've used this patching/authoring/patching method many times before without a problem, and the first two VOBs work fine here, so what could the issue be with the second two, and could it be fixed?
Simon
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 12:33 -
Authoring with Encore CS3, mastering with GPME - when to add ROM?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 13th Sep 2010, 14:04 -
Exporting from Premiere CS3 on PC to use in Encore CS3 on Mac
By meltait in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2008, 15:15 -
Encore CS3 Libraries
By vin4evr in forum Authoring (DVD)Replies: 0Last Post: 20th Feb 2008, 11:46 -
Encore CS3 menus
By vin4evr in forum Authoring (DVD)Replies: 0Last Post: 4th Feb 2008, 11:14
