Hi,
I've exported a .sub file out of a DVD movie which I bought.
Since I can't import the .sub file into Subtitle Workshop ("unable to load" error), because it's simply a bunch of pictures, I would like to import the timings.
What I mean by "timings" is the times that the subtitles show and disappear, so all I have left to do is to type the text of the subtitles, and then save it as a .srt file.
How can I do that?
Why not use subrip to OCR the subtitles from the 'bunch of pictures'? Ok, I don't know if Hebrew is supported by subrip. If you want to do it yourself, the timings should be in the index file ...idx which you probably have at the same place as your 'bunch of pictures'.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Extracted subtitle timing problem.
By Orange-kun in forum SubtitleReplies: 0Last Post: 2nd Mar 2011, 13:20 -
IMporting to Subtitle Workshop from txt file
By kouim in forum SubtitleReplies: 4Last Post: 27th Jan 2011, 17:26 -
Initial subtitle timing
By Smithcraft in forum SubtitleReplies: 2Last Post: 31st May 2009, 02:25 -
Enable editing of "Hide" timing of subtitles in Subtitle Workshop
By ecc in forum SubtitleReplies: 2Last Post: 31st Jan 2008, 07:35 -
Problems with timing using Subtitle Workshop
By Antus77 in forum SubtitleReplies: 1Last Post: 24th Jun 2007, 21:27
