I'm sure this has been asked a million times but I haven't found the answer I need. I have captured a 16:9 television program off my Directv HD receiver. It just happens to be from one of the lo def channels. Anyway, on my widescreen TV the program shows up being letterboxed and pillarboxed, even when directly viewed live. Is there a way to crop off the bars such that when I burn it to DVD it'll fill the entire sceen?
Crop 60 lines off the top, 60 lines off the bottom (or some other combination that totals 120 lines). Resize what's left (720x360) to 720x480. Convert to 16:9 MPEG2. Make a 16:9 DVD. Since you're source is interlaced you have to use interlace aware resizing. The result will look blurry.
ConvertXtoDVD 3 might be the easiest way to do it. It has many presets that you can flip thru and preview. Your quality may take a hit but the results may suit you.
letter and Pillar boxes
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2011, 14:43 -
Encore letterboxes widescreen footage
By koberulz in forum Authoring (DVD)Replies: 1Last Post: 19th Oct 2011, 00:58 -
[SOLVED] Is there a way to crop pillar boxes within FAVC before resizing?
By usually_quiet in forum Video ConversionReplies: 3Last Post: 3rd Apr 2010, 17:37 -
Letterboxes on side of video
By billyb14 in forum ffmpegX general discussionReplies: 4Last Post: 1st Dec 2009, 15:03 -
using graphics in Pillar bars with 4:3 video in a 16:9 project
By eyarea51 in forum EditingReplies: 3Last Post: 21st Nov 2009, 22:28
