Hi,
I am new to Mac Adobe Premiere. when I import, mac premier say I dont have the codec!!
any1 out there can help me on this stupid mac??? there is no problem at all in PC :{
Results 1 to 15 of 15
Hacked copies of Adobe Premiere are known to have import errors, so if you've not using a licensed copy, this would be your problem. Almost anytime I see Premiere complaints or problems, it tends to be due to using pirated versions, instead of the legitimate copies. Most licensed Adobe owners post questions on the Adobe support forums, or a few other places, if they need help.
Hi,
I cant play it on my Quicktime. I already download Divx as well as XVID.
thank you -
Hi Mr lordsmurf,Originally Posted by lordsmurf
I am using a LICENSE copy, and I also post this question on adobe forum and still waititng for their reply. -
You still have not said what the source of the video is, however if it is a downloaded Divx/Xvid file then Premiere probably won't like it anyway. Divx/Xvid is not designed for editing, and real editing tend not to like working with it.
I would try AVIDemux, which will do basic assemble editing and handles many common formats without the need for extra codecs.Read my blog here.
Try using MediaInfo (the Mac version) to get more information on the video and audio codecs used in the AVI, and post the information here. Alternatively, you can use VLC to get information on the video. If you have VLC and/or any version of mplayer installed, can you play the video without any problems?
If cameras add ten pounds, why would people want to eat them? -
YUY2 correspond to a raw video format and MediaInfo Mac will not give more infos about the file than VideoSpec as this one uses MediaInfo too.
see for example http://www.fourcc.org/fccyuy2.php
houdini -
Hi Ai Haibara,Originally Posted by Ai Haibara
I checked, is YUV codec, (but I cant find codec for MAC... irritating : [ )
Audio is PCM (Microsoft) -
Actually, I meant post all or most of MediaInfo's report here.
If you just want to convert the video, an alternative might be to see if it opens in VLC - VLC has the ability to transcode videos to other formats. Also, if anything that uses mplayer has no problems viewing it, mencoder (and anything that uses it, such as ffmpegx) will probably be able to convert it as well.If cameras add ten pounds, why would people want to eat them? -
Actually I want to work directly with .avi on my office mac machine, I dont want convert it, that why I desperately looking for the codec. My boss invested so much on this stupid mac, dont think they want me to convert here and there........Originally Posted by Ai Haibara
dv-avi on mac
By devdev in forum Capturing and VCRReplies: 2Last Post: 24th Oct 2010, 04:29 -
serious codec issues mac?
By aceswild in forum MacReplies: 10Last Post: 20th Nov 2009, 13:45 -
serious quicktime issue, basic MOV codec corrupt? mac
By aceswild in forum Video ConversionReplies: 1Last Post: 18th Nov 2009, 15:46 -
K-Lite Codec for mac
By pixel zombie in forum MacReplies: 3Last Post: 9th Jun 2009, 03:25
