using a regular video with chapters (and a chapter menu), is there a way in the Pgc Editor window to set the chapters to only play when selected? So selecting chapter 2 on the menu would only play chapter 2, and then return to the chapter menu? I'm pretty sure I've seen dvds that had that setup. The video in this case are trailers on one VOB.
Yes, that's possible with cell commands. Here is a similar thread:
https://forum.videohelp.com/topic350855.htmlGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Yes, cell commands can be used for going back to menu, but to keep the ability to play all material (if suggested in menu), this editing should be done in a separate PGC (copy of main PGC using same blocks - without changing file size). Although it is possible to use a single PGC and registers for organizing necessary behaviour, the presence of cell commands would cause pauses at playing all (seamless cell attributes can't be used there).
https://forum.videohelp.com/topic327036.html
Scroll down to see George W's step by step instructions on this.
Keep in mind that this allows for a Play All option, like Alex mentioned.44E -
You gotta be careful doing this, otherwise, the only way to play the movie will be chapter by chapter. Do establish a 2nd title for this (use the Clone PGC feature) and point your chapters to this title. Insert this type of cell command for every chapter (the resume will increment with each chapter):
Regards[30 08 00 00 01 83 00 00] 1 (CallSS) Call the VTSM Root menu of the current VTS, resume cell 1 <<---- make this the corresponding cell for chapter 2 etcLes -
Thanks, everyone. I tried the method outlined by George W - I'd done the same thing but didn't know what/where Cell command to use to end the playback. George also mentions to clone the PGC and link the PLAY button to it to avoid any playback pauses. Excellent.
I noticed this one-chapter playback only works during normal playing. If I fastforward or chapter forward, playback continues into the next chapter. Is there a way to make playback end in these circumstances (besides cutting the video into separate clips)? -
Set PUOs to stop fast forwarding or next/prev chapter (64, 128, 512, 256). While you're at it, you may as well set time play or search (32). Just enter 992 in the PUO field in the PGC Editor. OK and save.
You do realise that you are butchering the playback of the title, don't you?
RegardsLes -
Les,
thanks for the advice but it doesn't actually address my goal: I would like to FF/chapterFF within each chapter in this Vob, and not get into the next chapter when doing so. The PUO instructions prevent those playback options rather than prevent getting into other cells when FF/chapterFF. Maybe it can't be done without cutting the vob into clips?
I'm not sure what you mean by playback "butchering" - these are trailers all in one vob. The reason I need them in one vob (rather than individual clips) is for authoring ware limitations.
How to create chapter menu without thumbnails
By truongv0ky in forum Authoring (Blu-ray)Replies: 3Last Post: 4th May 2011, 16:05 -
PgcEdit Layer breaks color code
By Marco33 in forum DVD RippingReplies: 2Last Post: 13th Dec 2010, 06:23 -
Return to Title - NOT Chapter Menu - HOW?
By jlrm365 in forum Authoring (DVD)Replies: 7Last Post: 13th Mar 2010, 22:15 -
Pgcedit to go to main menu after a specific chapter?
By redsandvb in forum DVD RippingReplies: 4Last Post: 15th May 2008, 20:32 -
DVD Lab Pro - Play Chapter and return to menu
By SCDVD in forum Authoring (DVD)Replies: 4Last Post: 5th Dec 2007, 17:05
