I just bought a new gateway pc and was installing programs in it. I new to vista and dont know what happened. I installed dvdfab 5.3 and now my dvd drive won't work. I checkede device mamnager and there is an exclamation point under the drive. I tried to do a restore and that didnt fix it. I tried to update the drive and that didnt work. anyone what happened or how to fix this? Does dvdfab work with vista? I should have done some research before i installed i guess but it's too late now. Can someone please help me?
Results 1 to 13 of 13
In device manager right click and uninstall the drive and re-boot.
I think Vista will stop you installing something that does not work with it, oh ye of a lot of faith ! (me)
Also try downloading dvd fab again and reinstall, or uninstall it and see what happens after a reboot.PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Tried that-didn't work. asking for Pcouffin driver. I clicked search for it-didn't find it.
Pcouffin is installed with DVD Burning software, and is definitely installed with DVDFab. Reinstalling DVDFab should have put pcouffin back in, but if the hardware does not like it for some reason, then you will have the same problem. When you did the System Restore, how far back did you go? I usually go back a few days before the problem started - not just to the last restore point.
What kind of computer is it - Desktop or Laptop? What model number is the DVD Burner? Does the drive work at all - ie: Read Discs?"I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan ) -
Even if i get that ndvdfab to work i still can copt because i cant get my dvd drive to work. driver is missing. I went to gateway and there is no driver on the website either.b
I could only restored the pc back 1 day. It's a new Gateway Desktop. The drive wont read any discs at all.
The cable connecting the drive to the motherboard might be loose - this can happen when the computer is moved around in transit, since this is a new computer. You may want to open the case and check all the internal connectors, making sure that they are securely fastened.
does the drive function at all, like during startup when the bios scans for it? iow, can you put in a bootable system cd and boot from the cd instead of via the hard drive? if so, the problem is likely with in vista (prob a missing or misconfigured driver). if you can't boot from the dvd drive at all however, or the bios fails to recognize it, then the problem is likely in either the hardware and/or bios settings. check the power and data connection cables from the drive to the motherboard as well as the master/slave jumpers if applicable.
Ok, i got the drive recognized agian and did what moviegeek suggested. I unticked vso burn engine and it's working fine now. Thanx for the help guys.
How did you get the drive recognized? - Just curious what the problem was.
i un-installed everything and after several re-boots i think it fixed itself. I re-installed eveything except vso engine and just burned my first movie. This thing is fast, ripped and burned in 11 minutes.
DVDFab defaults to second drive as target
By audax in forum Authoring (DVD)Replies: 1Last Post: 22nd Nov 2009, 00:44 -
Ripped DVD using DVDFab, now my drive will not recognise any DVD
By Casseelynn in forum Newbie / General discussionsReplies: 11Last Post: 29th Jul 2009, 05:16 -
hard drive mystery with DVDFab 5
By paulcollegio in forum Newbie / General discussionsReplies: 4Last Post: 3rd May 2009, 06:53 -
Adding DVDFab AutoPlay Handlers for Vista x64
By TooLFooL in forum DVD RippingReplies: 1Last Post: 26th Mar 2009, 05:12 -
ISO movie seen on virtual drive but not recognized by anydvd / dvdfab..why?
By taratata in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 17:39
