ok I downloaded lord of the rings.mpg but the sound is off by like 15 seconds but the quality is so great that I would like to keep it so I may burn it.. So my question is, is there a way I can fix that or am I just screwed?
Look th the left column of this web page.
How to...edit.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
its a long process but you can load the mpg file into TMPGEnc and then select settings, in settings select advanced, at the top select the source range by double clicking the small box , this allows you to select the start and end point of the movie but also the sound offset
hope this helps :PDont feed the little Varmits too much -
yeah I found the guide that tells me how to go about to re-sync the sound...but I tried it about 6 times and everytime I get a high pitch sound at the begining of the moive...then no sound...So I'm going to re do it about another dozen times...but if someone can tell me why I'm getting that sound it will help me out alot
