    Feb 2008
    Portugal
    Hello.
    Using VirtualDubMod to add permanent subtitles to an AVI, the guide of Baldrick (https://forum.videohelp.com/topic272736.html) doesn't refer the variation of the characters. So, is it possible to increase the size of the letters? If yes, how is it possible with VirtualModDub?
    Thank you the help.
    Cheers.
    Click on the styles(see the last image in the guide) and you can change the size. It will only work with textsubs though, if you have image sub/idx vobsub it wont work(convert them to text using subrip instead).
    Feb 2008
    Portugal
    Yes, Baldrick, I saw that but it only refered to outlines(?) and shadows(?).
    I'm going to study better these "Styles".
    Thank you and good bye.
