Im looking at buying the Samsung r610-64g laptop, which has an hdmi connector. I want to connect it to my Samsung ln4095 1080p hdtv.
Stupid question: if I connect these two products via hdmi, can I assume that I will see a pristine picture on my tv that looks identical to what I see on my computer screen? Same brightness and clarity?
Results 1 to 12 of 12
I was hoping that would be the case.....but just to clarify so I am understanding:
Lets say you have two video cards....a basic $100 256mb card and a top of the line $600 super video card. Both cards have hdmi outputs on them.
My question is.....will both cards yield the same results when connected to an hdtv? -
If in the same family probably yes. Give us some model numbers.Originally Posted by hygieneboy
The main difference will be game performance and maybe h.264 playback. If spec'd for Blu-Ray, it needs to handle h.264 and VC-1 at Blu-Ray bit rates.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
UPDATE:
I bought an hp laptop and connected to my receiver via hdmi, and the picture looks great. HOWEVER.......
I cant figure out how to get the sound to play through my tv speakers. I have connected via hdmi, which I know is supposed to carry both the sound and the video.
Anyone have any advice?
HP DV7-1247cl computer
Harmon Kardon AVR254 receiver
Samsung LN4095 1080p TV -
i did see a setting on windows under sound that gives me the option to change from computer speakers to hdmi output, and I selected that, but it still didnt work.
Ill try your suggestion next.... -
I think that's pretty much the same thing I was suggesting. I would try rebooting after making the change.Originally Posted by hygieneboy
Tried it...no luck. Picture looks great, but not a peep from the speakers.
If anyone knows of another way.......
ty -
I have not treid it yet but my brand new Toshiba laptop has a HDMI shortcut on the desktop.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
What video card is it? Onboard audio?
I know you are talking about a laptop, but on desktop systems, you need to hook up the HDMI passthru cable from the soundcard to the videocard so the audio is routed into the single HDMI out -
Found my problem......had to go into the special audio software that came with the computer and change it there. The general sound tab in the control panel did not work.
Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
By SOHkat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Oct 2010, 14:50 -
Default Connecting laptop to HDTV - wanting best quality HDMI to DVI conn
By mr-scarface in forum DVB / IPTVReplies: 8Last Post: 24th Aug 2008, 14:59 -
Connecting DVD player through HDMI: 2 Problems
By Markaveli in forum DVD & Blu-ray PlayersReplies: 10Last Post: 22nd Aug 2008, 07:40 -
Problem Connecting PC to TV via HDMI
By M.AD in forum Media Center PC / MediaCentersReplies: 1Last Post: 23rd Feb 2008, 17:05 -
Connecting the pc to tv via HDMI
By alintatoc in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2007, 13:48
