The Firewire on my Sony D8 Handycam suddenly stopped working. I have two computers that both have IEEE. Both cannot capture.
Before sending the camcorder in for repair, I’m aware it could be my cable. Before purchasing one, has anybody else had this same problem and it turned out to be the cable?
On 2-4-09 edDV suggested to remove the battery for a long period then replace it to force a firmware reboot. Unfortunately, this did not fix it.
Thanks,
Mark Smith
Do you or anyone you know have another D8/DV camcorder that you can try with your cable and PC?
John Miller -
I tried to do that a while ago, got it all set up, but the guy was a no-show. So, your answer is "no." Maybe there is somebody else I haven't thought of.
my burner stopped burning dl only
By ninjinturdle in forum Authoring (DVD)Replies: 8Last Post: 21st Jun 2011, 13:12 -
Need help-Been using ripbot for sometime now....it has stopped working.
By clefus in forum Blu-ray RippingReplies: 3Last Post: 13th Jan 2011, 11:42 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 07:07 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19
