I got a dual audio file that comes with one file that is .OGM and another that is .SSA, I was wondering if there is a program to put these two files together so that the subtitles show up.
I'm not big on video editing or anything, how would i do that?Originally Posted by Placio74
If you are playing it on a computer then just use vsfilter and then rename the video and subs like video.ogm and video.ssa and play with windows media player or mpc and the subs should appear.
Or do you want burned in/permanent subtitles? Then must you reconvert, use for example xvid4psp or avidemux. See https://forum.videohelp.com/topic360276.html -
Use MKVtoolnix.
In mkvmerge GUI add .ogm and .ssa files and just mux to MKV. -
Thanks a lot, it seems to be working.Originally Posted by Placio74
Is there a hardware/software combination that can capture Anamorphic TV
By Phuzzy in forum Capturing and VCRReplies: 9Last Post: 27th Oct 2011, 05:30 -
Best combination of Sofware and media
By stallion2008 in forum Authoring (DVD)Replies: 8Last Post: 28th Oct 2009, 16:49 -
Best DVD playback combination for PAL users
By Dark Alpha in forum Software PlayingReplies: 0Last Post: 18th Jan 2009, 11:54 -
What is the Best Combination for Quality?
By drxpsp9 in forum Newbie / General discussionsReplies: 10Last Post: 30th Jul 2007, 16:43 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 14th May 2007, 23:33
