Quick question,
I'm using this calculator here: http://www.divx-digest.com/software/video_resize_calc.html - and when I enter in 1920x1080 - how come I get 1280x720 as valid but not 960x540 OR 704x396??![]()
Results 1 to 15 of 15
Valid for what?
http://www.kiva.org/about -
In the calculator under "available valid resolutions"Originally Posted by edDV
What are you trying to accomplish?
960x540 is quarter resolution, half motion sample of 1920x1080i that is the poor man's deinterlace favored so much by Apple.Recommends: Kiva.org - Loans that change lives.
I'm just trying to figure out the possible frame sizes with an particular aspect ratio.... and I know that 960x540 & 704x396 should be listed. Do you know of a calculator that will give me all the possible listings?
It depends again on target.Originally Posted by tb582
If you stay with square pixels, any 16:9 ratio will maintain aspect ratio. If you are working with non-square pixels, the choices are limited by the codec and media format you intend to use.Recommends: Kiva.org - Loans that change lives.
it might be because that program hasn't been updated in 8 years.
not sure why you would need a calculator to get a valid 16/9 size. just choose your horizontal pixel number multiply by 9 and then divide by 16. -
[quote="minidv2dvd"]
what about for a 2.35.1 or 2.40.1?Originally Posted by tb582 -
[quote="tb582"]
for 1920 horizontal pixels in,Originally Posted by minidv2dvd
1920/2.40=800 vertical pixels or 1920x800Recommends: Kiva.org - Loans that change lives.
take your horizontal and divide by the aspect ratio, i.e. 1920/2.35=960
16/9 is 1.77777777....... so 1280/1.77777777=720.00000315
[edit] point to eddv for faster typing -
math was never my thing so forgive my ignorance but why with the 16:9 do you take the horizontal number multiply by 9 then divide by 16, vs with the 2:40.1 you take the horizontal number and divide only by 2.40?
Do a goole search for Aspect Ratio Calculators and you will find a lot of them out there, including simple ones like this : http://andrew.hedges.name/experiments/aspect_ratio/ which works for 1:1 PAR.
Read my blog here.
16:9 and 1.777777777to1 are two ways to say the same thing. It is a simple ratio. We aren't even doing algebra here.
How about a 2:40:1 video at 1920x800 - I want to keep the DAR 12:5 and PAR at 1:1
Neither 540 nor 396 are exact multiples of 8 (or 16). That's probably the reason.
John Miller
What is the best Bitrate Calculator ?
By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 08:08 -
bitrate calculator for multiple audio?
By ecc in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 20:25 -
bitrate calculator
By pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 11:34 -
videohelp bitrate calculator question
By mrgain in forum EditingReplies: 5Last Post: 24th Oct 2007, 15:56
