Trying to convert a AVI movie to MPEG so I can evetually make a DVD. I have done this many times using "Gary's fool proof guide". Which has you use VDUB to save a WAV file from the AVI and then use TMPGEnc Plus to convert the AVI and WAV file to a single MPEG file.
When I do this with this particular movie - it creates a MV2 file instead. Which I cannot use with with TMPGEnc DVD author to create a DVD.
Why is it creating a MV2 file and how can I get it to create a MPEG ?
TIA
A m2v/mv2 is a mpeg2 video only file and should work fine to import in tmpgenc dvd author. TMpgenc Plus should also make a separate wav file that you also need to add in tda.
If you want ONE mpg file from tmpgenc plus you must choose mpeg layer 2 audio instead of wav/pcm audio(in the first step in the wizard mode). -
In the Stream Type section of the TMPGEnc Plus Settings dialog select "System (Video)" or "System (Video+Audio)". Those will give you an MPG container rather than an elementary stream.
And you can only select the above stream types if you use mpeg layer 2 audio so choose that first...
ripbot only converts half the movie
By AmDD in forum DVD RippingReplies: 8Last Post: 11th Feb 2012, 07:50 -
Need to find a program that converts to MPEG-2 Transport Stream
By rprice806 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 13:10 -
RipBot converts only half the blu-ray movie.
By Obamargarine in forum Blu-ray RippingReplies: 6Last Post: 18th Feb 2009, 23:35 -
Demuxed mpeg to mv2,mp2 with command line
By vtr in forum ProgrammingReplies: 4Last Post: 15th Sep 2008, 03:22 -
I shot a movie in 16:9 but when iMovie converts it to quicktime...
By Elwray in forum MacReplies: 11Last Post: 14th Jul 2008, 02:28
