is it possible to repair a movie with corrupted frames by using a hex editor?
Say I wrote you a letter. Somebody came along and transcribed it with a pencil onto a new piece of paper. But he made some mistakes. Maybe some were simple spelling errors. Maybe he left out entire words or paragraphs. Maybe he just added some random text here and there.
Given only that copy, a pencil, and an eraser, can you fix the letter? Depending on how corrupt it is, you might be able to fix it. But as the number of errors increases, and the complexity of the errors increases, it gets harder and harder. Especially if the letter is written in a language you don't understand. -
With a touch more subtlety; probably not.
How many frames? Are the bad frames sequential? Maybe cut out the bad frames. If Ok can you post a sequence of good ---> bad ---> good frames -
If your goal is to make enemies here or to convince everyone that you are a complete idiot, then this was the perfect response to jagabo's post.Originally Posted by demonwarrior
To answer your question another way that you might understand better as I think jagabo has understated the difficulty of what you propose (a hex editor? Yikes!!!), you'd probably have a better chance of buying a winning lottery ticket than successfully repairing this kind of damage with a HEX EDITOR. Note that demonwarrior did NOT ask if this damage could be repaired using a video editor but specifically asked about using a hex editor.
I have one question for you in case you don't understand my reply either. Exactly how do you expect to find out what the correct hex values are to repair the file? If you can come up with the correct hex values, then you are in a position to try what you propose.
Corrupt audio, need help
By madhorror in forum AudioReplies: 5Last Post: 22nd Apr 2012, 22:00 -
video gone corrupt
By beep911 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 13:58 -
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 17:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
corrupt dv-file
By pdehon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Nov 2007, 08:24
