There's a pretty hilarious bad antenna thread over at Digital Home![]()
http://www.digitalhome.ca/forum/showthread.php?t=35083
Also there is a lot of useful info there about OTA in general; splitters and ganging Channelmasters and suchlike... http://www.digitalhome.ca/forum/forumdisplay.php?f=81
AS The Man with No Name once said: "In these parts, sometimes a man's life depends on a mere scrap of information." 8)
&... If you bought a lemon post it here...
I bought one of these Zenith antennas as it had a lot of recommendations:
It did pick up about 15 HDTV stations after I connected it to a RF amplifier. Then I unplugged it, leaving the four foot coax hanging out of the amplifier and forgot about it. About a week later I checked my HDTV tuner and saw that I now got 23 stations with a clean signal on all channels just from the disconnected coax hanging down the wall. The Zenith antenna was worse than just a piece of wire.
I have since mounted a regular long boom antenna in the attic and get 29 HDTV stations, all with good signal strength.
EDIT: I should also mention that a $.99 set of rabbit ears from a flea market outperformed the Zenith by quite a bit.
Greetings ....
If I recall the slogan right --
"ZENITH - The quality goes in, before the name goes on."
Who makes the RF amplifer and the cable? Where did you buy them?
Thanx-A-Lot, Frank-0-Video -
It was about four feet of bulk RG-6 Belden, hanging out of the amp and extending towards the floor. The amplifier is a Channel Master 3044. It feeds to a HD Homerun LAN HDTV tuner. Most HDTV stations are now running at full power, so it's not hard to get a signal if you have line of sight to the transmitter towers. I also pick up a couple of stations that are about 50 miles away with the attic antenna, but not a good signal, a lot of dropouts.
Red- I'd have bought one of those too!
Just FYI, couple days ago PBS Newshour was discussing DTV antennas and mentioned in passing that the FCC has overruled all local rules & ordinances banning rooftop antennas.
Does Bigger = Better when it comes to TV Antennas
By the_importer in forum DVB / IPTVReplies: 10Last Post: 4th Jan 2012, 12:52 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
Digital Roof Antennas (?)
By Seeker47 in forum DVB / IPTVReplies: 6Last Post: 1st Jun 2008, 13:50 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45
