Hey guys I'm new here and I'm at a last hope for some help with this. I hope this is the right place to post this.
I made the mistake of filming scenes from a movie some friends and I are making on a DVD-RW disc. I hadn't realized doing this created a .VRO file instead of a typical .VOB DVD video file until I went to copy the disc to my computer. With that being said the only way I can convert that is by converting the whole thing at once. Is there any software out there that will auto-split or auto-chapter the the 71 scenes from the .VRO file into individual ones? I really don't want to have to go through and break every scene manually but I will if I have to as long as I can get some proper software. Everything I am finding on the internet isn't really what I want to do at all.
My scenes are also in widescreen 16:9 format so I would hope there is something that won't modify that.
Thanks a bunch!
	I think TDA or TMPGEnc Authoring Works may be able to do what you want. They are not free software, but have a free trial. I believe both can detect timecode breaks and split VRO files using them.
	Hi
 Only just noticed this thread so you may have already solved the problem. There is a program called "VROSPLIT" which I have used to split the files into their separate parts and save them as mpeg files. I cannot confirm the aspect ratio is not changed.
 The program is available as a .deb file or source code as is run from command line ,but the site is Japanese and I used google translate to read it.
 john
  VRO file (VideoCAm) to DVD degrade the video ?By c1steady in forum Video ConversionReplies: 0Last Post: 28th Apr 2010, 04:08
  ever heard of a vro file?By uglijimus in forum Video ConversionReplies: 11Last Post: 28th Apr 2009, 00:30
  Converting .VRO file onto a DVD disc (to play on standard DVD players) ?By superman123x in forum Video ConversionReplies: 21Last Post: 24th Mar 2008, 18:40
  how do you convert a vob file into a vro file?By johnsteed in forum Video ConversionReplies: 29Last Post: 13th Sep 2007, 08:12
  Extracting .VRO file from DVD-RAM to pc for editingBy mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 14:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
