Those codecs are so similar to each other, unless those DivX files were transcoded with very recent versions of the DivX codec, all you need to do is change the file extension from .DIVX to .AVI, then change the internal codec descriptor in the files with an app like this:
http://www.winremote.dk/fourccchanger.php
You have to type in the word XVID in each field
Should take all of 30 seconds to do
If that doesn't work, or your version of DivX is too new, try to re-encode with this app:
https://www.videohelp.com/tools/AVI_ReComp
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 09:12 -
Batch conversion of large numbers of DV-AVi to Xvid/Divx
By snehne in forum Video ConversionReplies: 2Last Post: 19th May 2009, 18:04 -
Xvid/DivX avi to smv conversion
By marcopolo1 in forum Video ConversionReplies: 3Last Post: 17th May 2008, 08:49 -
My Conversion Dilemma for PS3 Xvid -> DivX and MKV -> AVI
By Alterego in forum Video ConversionReplies: 0Last Post: 30th Mar 2008, 04:10 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09
