So many video formats in the market, that they are not compatible such as .smv, .wmv, .mov etc. (really do not know how many different videos formats right now and hopefully someone can list all and their makers). What is the good video conversion tool that can efficiently and effectively convert the most of video formats each other?
Results 1 to 10 of 10
And it will almost always do so at the lowest of quality.
Easy
Quality
Fast
Pick one, maybe two.Want my help? Ask here! (not via PM!)
"Best" is too subjective and cannot be answered. How about AVS Video Converter - I see it advertised everywhere including at the bottom of this page.
If you want an answer then define "best". Best to you might mean "fastest" because you go nuts if it takes more than 1 hour to do. Best to another guy might mean "easy' because he doesn't understand much about the subject. Best to another person might mean "best quality" because he doesn't care how long it takes and he understands the subject, he just wants the final result to look as good as possible.
I guess for your vague needs the program called Super is pretty easy to use and while it doesn't produce the highest quality output, it just works and it's good enough for a lot of people. Try it and see if it does what you want.
By the way, NOBODY is going to spend the time to list all the video formats and who owns them. Good luck with that. -
If you google for the file extension you will find that there are few lists around that will tell you what and who. Some of those - .smv, .amv etc. are fairly obscure and only supported by specific tools, not general converters. Which is not a bad thing given how crappy the output of some of these formats is. For the most common formats I like Xvid4PSP. It produces good quality output, is flexible, and covers a good range of input and output types. SUPER covers more, but the quality is not as good, and it is more prone to refuse to encode.
Read my blog here.
SUPER is good as an all in one video converter, as a 1st time user it might taking some getting use to the gui.
One you get the hang of things you can then start comparing it to other conversion tools and start looking at specific tools for specific vidoe formats.Everyone lies.
The innocent lie because they don't want to be blamed for something they didn't do, and the guilty lie because they don't have any other choice. -
VideoStudio good at converting videos to other formatts.
The good tool should be able to convert most of the video formats (not just a couple of popular formats) so the user does not have to change the tools frequently. The advertised one is not always good because it needs to advertise to the public. The user experience sometimes is worth more.
A linux tool for detecting glitches in video files (of varying formats)?
By jemenake in forum LinuxReplies: 1Last Post: 16th Feb 2012, 19:42 -
Best all round tool to convert video formats, basic editing, etc.
By ian_g in forum Video ConversionReplies: 9Last Post: 16th Mar 2011, 06:21 -
Tool to Convert Single File to Multiple Formats Simultaneously
By pabling19 in forum Video ConversionReplies: 1Last Post: 15th Mar 2011, 13:13 -
Selecting Video Formats to Convert to
By ctdvd in forum Video ConversionReplies: 5Last Post: 7th Jan 2009, 12:06 -
How to convert .scm to avi or any other video formats?
By xmartin86x in forum Video ConversionReplies: 2Last Post: 9th Jan 2008, 11:35
