Hello, Ive done a bit of research and found that theres no way to resize a 4:3 video to 16:9 widescreen without cropping it? Is this true?
the source video is 704 x 576, if I just resize it to 704 x 480 - the picture is still a bit "fat", if you know what I mean.
thanks
You can add black bars to the right and left sides followed by a resize to make it 16:9 (or resize followed by adding black bars). That's commonly done when the video is a mix of "fullscreen" and "widescreen" sources, like documentaries sometimes. But that's probably not what you had in mind. So yes, to convert it to 16:9, ordinarily you crop from the top and bottom and resize.
ok, thanks for your answer....thats a shame, to crop that much from top and bottom I need to check first if theres anything important in that areaOriginally Posted by manono
I'm cropping now, will test how it looks on HDTV.
You could always watch it the way it was created and intended to be watched. On a widescreen TV set that would be with the pillar bars on the sides of a 1.33:1 video. Then you wouldn't have to go through the trouble of butchering the video and creating a much inferior copy.
AVI, mpeg2 or mpeg4?
By maxamillion in forum Video ConversionReplies: 6Last Post: 16th Jan 2009, 07:30 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 09:44 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 01:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 19:42 -
avi to mpeg2
By n2lakers in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 15:56
