Is there a tool out there that will split a 47 minute MP4 video into <10 min parts for uploading onto youtube (part 1,2,3,4,5) (without re-encoding) ?
What do you mean by copy segments? I'm downloading the tool now. Will it allow me to copy segments that I specify to new MP4 files?
Yes, the original is untouched. You copy part 1, 2,3,4,5 segments as new segments.
Set your mark in/mark out (using keyframes is a good idea)
Set video=>copy
audio=>copy
format=>mp4
press save with extension (eg "file1.mp4")
It isn't frame accurate if your video is h264, so cut on keyframes. If the video is xvid, it will smart re-encode only around the cutsite if not on a keyframe (i.e. you are not limited and then you can cut anywhere)
Another option is to use mp4box (YAMB is the GUI) -
Interesting, I just tried the YAMB and it split the file exactly as I wanted it into parts, however, when I play each MP4 file, the duration shows the total length, but of course it only plays up to the split point. I'm going to try and upload a segment to youtube to see if it complains or accepts it...
Sony PMB (Picture Media Browser ?) ver.4.2. is a great yet simple tool to split effectively MPEG4 (.mp4) files. It comes free with Sony digital still cameras.Originally Posted by sdsumike619
What program can I use to cut segments from a mp4 video?
By alc112 in forum EditingReplies: 9Last Post: 1st Jul 2011, 19:31 -
Split mp4 file into 10 minutes parts in order to upload on youtube
By vitcon in forum ComputerReplies: 4Last Post: 11th Mar 2011, 14:30 -
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 07:19 -
Joining Youtube Segments?
By LuluShaBoom in forum EditingReplies: 2Last Post: 26th Mar 2010, 11:30 -
AVI - split by no. of segments
By macpraveen in forum EditingReplies: 4Last Post: 13th Jun 2009, 00:30
