    Jan 2003
    Milwaukee
    Is there a way I can force it to format it to NTFS? If I try NTFS, it gives me an error that it cannot format because the device was not recognize or something... But If I try FAT32, it works fine... My Camra's, only read NTFS.
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    There should be a way to format it from the camera.
    Buy My Books
  3. Originally Posted by Johnnylee_hang
    give SwissKnife V3.22 a shot
    Jan 2003
    Milwaukee
    the camra can't even read it; how can it format it? XD
    that program i installed, but vista won't accept to run that. Even with Run as Admin... It'll pop-up that that program has stopped working...
  5. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    It can't read it because it's not formatted in the format it needs? Usually there's a menu option somewhere to allow you to format the card. Or maybe you need HS SD and you purchased a basic SD, or you purchased HCSD and you need basic SD... hard to say without knowing what Camera you own or which SD card you purchased.
    Buy My Books
  6. Originally Posted by Johnnylee_hang
    you don't own any PC's with XP ?
