    Feb 2008
    Portugal
    Please help me in the following matter:
    Playing at the DVD Player there are some movies that the audio is very low.
    Is there any process to increase the sound of the audio of the file?
    Thank you and cheers.
    Oct 2006
    Canada
    Sometime, if you turn off dynamic range on you DVD player setup, you may use volume control to get sound to your liking. It will not go from really loud to really quiet.
    Otherwise you will have to demux, fix it in audio editor and mux it back.
    You may loose 5.1 feature.
    Feb 2008
    Portugal
    Thank you, Tinker.
    I'm going to demux/mux as you said.
    Cheers.
