Hi to all,
as in the topic subject, I'm looking for a way to backup BR main movie ( without video encoding ), main audio track AND subtitles. As far as I know ( correct me if I'm wrong ) toNMT ( I have Popcorn Hour A-100 ) doesn't support subtitles and in the near future not going to. Ripbot264 can do the trick but with video encoding, makeMKV can save subtitles but in PGS format which is not supported by A-100. Are there any other options that I missed ?
Thanks in advance for any suggestions.
Baldrick - thanks a lot for your reply.
I understand that with file produced with makeMKV + .srt subtitles file I should have movie with switchable subtitles ( on/off ) ready for A-100.
According to your reply would you help me with one more step in this procedure.
At the moment, I know that I can get .sup subtiles file from temp folder when I start working with ripbot264.
Is there any other way to get .sup file from BR disc then that ?
How do you do main movie hd-dvd to avchd in multiavchd with 2+ audio tracks
By yoda313 in forum Video ConversionReplies: 2Last Post: 27th Sep 2010, 21:18 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 02:13 -
Help w/BD Main Movie PiP DTS-Express Audio
By infocup in forum Blu-ray RippingReplies: 4Last Post: 2nd Mar 2009, 18:14 -
What is the main reason you backup dvds?
By yoda313 in forum PollsReplies: 15Last Post: 25th Jun 2007, 13:52
