Is it important to correct a 23.976 file to 29.97 before authoring, using a specific program like DGPulldown?
Or authoring programs like DVDLab Pro or TMPGEnc DVD Author will do that properly?
What I have noticed is that if I load an uncorrectec 23.976 file in DLP it will show wrong time on the timeline.
But I did burn the disc anyway and it plays fine. So what should I do?
The final size does not change after passing through DGPulldown, so what does it do really?
Will processing improve or worsten the image quality?
DgPulldown adds 3:2 pulldown flags that tell the DVD player on how to create 59.94 fields per second from the 23.976 frame per second video. Some players will not play the files correctly without the pulldown flags.
I don't think DVDLab Pro or TMPGEnc DVD Author will add those flags while authoring. -
DVDLab Pro requires the pulldown flags already be present before authoring, and also has a tool to add them built-in (I believe - it's been a while as I use DGPulldown)
Read my blog here.
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 16:53 -
3:2 Pulldown and Interpolation
By PuzZLeR in forum Video ConversionReplies: 1Last Post: 28th Oct 2007, 11:49 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 06:38 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 03:25
