I have a DVD that was created with a camera. Every time the camera is stopped and started, a new chapter is created, so there are a few "false starts". I'm assuming I need to rip the DVD to files (can I just copy VIDEO_TS and AUDIO_TS ?), use something to delete these chapters, maybe be able to rename the chapters that are left (so instead of "Chapter 1", "Chapter 2", etc. I can call them what I want?) and then burn the edited files to a blank.
I assume ImgBurn would be the tool for the first and least steps, but I don't see an IFO mode any more. And to edit the files, I'd really like the simplest tool to use, not the "best" or most powerful, so I can just get this one little project done.
I think in your case would be better to use VobBlanker. Load your VIDEO_TS in and delete cells you do not need. VobBlanker will load IFO file.
Do not worry about AUDIO_TS , it is empty. -
If it were extra chapter/program problem it could be cured in 2 clicks with DVDRemake by deleting program attributes from cells.Originally Posted by jnojr
Probably you have time code problem: every new recording session timecode begins from zero (and maybe also a still mpeg picture inserted). Usually there are problems with browsing through the file even in VideoReDo, Womble etc. Sometimes the following method helped me: demux video in DGIndex (after importing VTS' VOB group) -> import it into DVDLab -> apply Rewrite GOP Timecode from options (it works in place, so keep your backups). Then cut-edit if necessary and re-author.
How do I virtually'delete' a DVD-R, so that I can add other Video_TS to it?
By KneeRow in forum Authoring (DVD)Replies: 45Last Post: 18th Dec 2013, 23:36 -
LG HDD DVD recorder won't delete
By kimmie23 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Feb 2010, 02:27 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
What happens when you 'delete' stuff from a DVD before writing to DVDR
By mtdg in forum DVD RippingReplies: 9Last Post: 7th Nov 2008, 08:51 -
How can I delete close captions from a DVD
By siopilos in forum SubtitleReplies: 3Last Post: 26th May 2008, 10:31
