Ok heres the deal-
I have absolutely no idea what I am doing. All I know is that I have a Sylvania 6727DG dvd player thats plays region 1 dvds and i have lots of region 2 dvds that I want it to play. Can anyone help me please? I have been looking all over the internet and i cannot figure out what the code is. So if anyone knows what i need to do- please share, it would be very much appreciated.
thanks,
reeldancer
No region hack has been reported for this model, and not all DVD players are hackable. Are your region 2 discs from Japan or Europe? If they come from Europe, they will not only be Region 2, but also PAL system, which won't be viewable on your player even if you find a region hack. Japanese DVDs, however, are NTSC discs (compatible with US system). In that case, your option would be to make region-free backups. If your computer has a DVD burner, you could rip your Region 2 discs to the hard drive using DVDFab HD Decrypter, then burn to a blank disc using ImgBurn. (If you need to shrink a long movie to fit on a 4.7GB blank DVD, you'd also need to shrink it down using DVDShrink before burning.) The backup copy will be region-free.
If the originals are European PAL system, you may have to resort to purchasing a multi-system DVD player.
According to my information, the Sylvania 6727DG is a TV/DVD combo. The likelihood of finding a region hack for it is slim.
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 15:44 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 13:42 -
Sylvania DVL245G to Region Free
By roadstomandess in forum Authoring (DVD)Replies: 0Last Post: 19th Nov 2007, 15:21 -
Region free hack needed for Sylvania dvl245g
By cosmo09 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Nov 2007, 14:46
