I'm not looking for hd quality here, just for some xvid files or random movies ive got laying around.
if they've got 5.1 channel i downmix them to 2 channel
what i want to know is if 128vbr mp3 is preferred over 100kb vbr aac. im looking for whatever i can to save the MOST space, without noticing quality loss on standard speakers.
i notice most xvids are 128kbps, but 100 aac seems kind of low, regardless of it being aac.
The difference is you are re-encoding from a lossy rip, where the xvid movies had a better quality source, likely original DVD or blu-ray.
Everytime you re-encode using a lossy format you irreversibly lose more quality
This applies to both the audio & video.
If you started out with the same source, the the AAC will likely slightly sound better in most cases. NeroAAC yields better results than CT-AAC
You don't save much space shaving off 28kbps... and hard drives and DVD media are pretty cheap these days -
According to the official info, "-q 1".
<COMMAND LINE>
</COMMAND LINE>Code:[C:\] =>neroaacenc -help ************************************************************* * * * Nero Digital Audio Reference MPEG-4 & 3GPP Audio Encoder * * Copyright (C) 2006 Nero AG * * All Rights Reserved Worldwide * * * * Package build date: Feb 12 2007 * * * * See -help for a complete list of available parameters. * * * ************************************************************* Usage: neroaacenc [options] -if <input-file> -of <output-file> Where: <input-file> : Path to source file to encode. The file must be in Microsoft WAV format and contain PCM data. Specify - to encode from stdin. Note that multiple input files can be specified, they will be encoded together into a single output file with chapter marks indicating source file divisions. <output-file> : Path to output file to encode to, in MP4 format. ==== Available options: ==== Quality/bitrate control: -q <number> : Enables "target quality" mode. <number> is a floating-point number in 0...1 range. -br <number> : Specifies "target bitrate" mode. <number> is target bitrate in bits per second. -cbr <number> : Specifies "target bitrate (streaming)" mode. <number> is target bitrate in bits per second. When neither of above quality/bitrate options is used, the encoder defaults to equivalent of -q 0.5 Multipass encoding: -2pass : Enables two-pass encoding mode. Note that two-pass more requires a physical file as input, rather than stdin. -2passperiod : Overrides two-pass encoding bitrate averaging period, <number> : in milliseconds. : Specify zero to use least restrictive value possible (default). Advanced features / troubleshooting: -lc : Forces use of LC AAC profile (HE features disabled) -he : Forces use of HE AAC profile (HEv2 features disabled) -hev2 : Forces use of HEv2 AAC profile Note that the above switches (-lc, -he, -hev2) should not be used; optimal AAC profile is automatically determined from quality/bitrate settings when no override is specified. -hinttrack Generates an RTP hint track in output MP4 file. -ignorelength : Ignores length signaled by WAV headers of input file. Useful for certain frontends using stdin.
MP3 (LAME) in Avidemux
By moiz in forum AudioReplies: 2Last Post: 18th Feb 2012, 10:18 -
How to export Lame MP3 to custom bitrate?
By Artas1984 in forum AudioReplies: 6Last Post: 17th Sep 2011, 14:29 -
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 16:13 -
MP3 (LAME), AAC (FAAC) and AC3. Can we rank them?
By moiz in forum AudioReplies: 3Last Post: 17th Oct 2008, 14:57 -
MP3/LAME and H264/X264
By Xavier in forum Newbie / General discussionsReplies: 3Last Post: 15th Apr 2008, 22:53
