I have this ex HDD here.. it's a 5.5" i think and it uses power supply. Basically it's about 3 years old now. It has no OS installed on it and is just a backup hdd for stuff.
Now prob is, one of the folders cannot be accessed. It says I/O error...what'as causing this? If it's hardware it should affect the other folders right? How is it only one particular folder is affected?
In case something has gone terribly wrong, any way to retrieve the data in that folder? Any prog or solution?
Thanks in advance all!
PS: I just tried defragment and it is sorta jammed...perhaps the hdd is dying? Or could it be the USB cable?
I suspect the drive is failing and the clusters which hold the folder in question are damaged. Use the disc tools supplied by the drive manufacturer to test the drive. They should be on the CD which came with the drive, or you can download them from the manufacturer's website.
Google is your Friend
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
device error
By alintatoc in forum ComputerReplies: 7Last Post: 8th Jan 2010, 11:53 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
Error "no usable writing device installed"
By saramalik in forum DVD & Blu-ray WritersReplies: 5Last Post: 23rd May 2008, 04:42 -
I/O device error
By volam in forum ComputerReplies: 6Last Post: 2nd Apr 2008, 09:22
